AligatorAmy
Bioengineer
I have the machine component which size is 2m x 0.2m x 0.4m (component is sorounded by enclosure, as outlined on attached draft).
Component has a couple of metal braided cables which have their inlets along the longer side (2 meters).
Component is made of mild steel and its working temperature may reach 250degC.
I am developing a new system for the cables collection along the 2 meter side of the component.
The difficulty is that I need to fix this system to this component (it cannot be fixed elsewhere) and simultaneously I need to thermally insulate this system from the hot component.
Component is disassembled periodically (every 6 weeks) from the machine for refurbishment, thus its construct, that includes also cables collecting system, must be properly designed from design-for-assembly perspective.
I consider a system as outlined on the attached draft.
It is quite simple. However, I am not certain how to effectively thermally insulate the system (in my design a part called 'ring', see draft) from the mild steel component. One option seems to be a ring made from material of lowest thermal conductivity but capable to withstand ~280degC.
P.S. In presented concept each ring is inserted on a threaded mild steel bar which is already present in component design.
Please help.
Thank you
Please help.
Thank you
