Hello, I have doubt with calculation of minimal gap due to tolerance stacking but under thermal impact on high temperatures.
Attached is sketch drawing with two examples one example is calculating radial direction of tolerance stack-up of rod and tube and second one is calculating liner stack-up of parts in simple assembly.
Calculation is conducted for first example with tolerances that we have smallest inner diameter of tube and highest diameter of rod and I am checking what is final gap when parts are heated on 120°C. For second example tolerances for parts are used when they are at max plus tolerance. What is confusing me is this case where I have assembly how to properly calculate his thermal expansion when I have formula for thermal expansion Δl = α*l0*(t1-t0)where α is coefficient of thermal expansion and it is specific only for one material of one part not for assembly where we have couple parts with different materials. Does anybody have idea how to proper calculate this when we have thermal expansion for assembly?
Attached is also my calculation with marked cells what is confusing me.
