Dear Sir
I try to size the relief valve on the a cooling coil discharge side.
And, there is a failed closed control valve on the liquid discharge line also.
I am not sure that the two scenairo, thermal expanision and blocked outlet have or not.
If we close valve on the cooling water return side, it seems not likly cuase a thermal expansion releif cause there is not any blocked valve on the upstream side.
Could you please tell me how to tell the thermal expansion exist or not?
Then, I try to calculate the blocked outlet relief load through Ferris PSV softwrare, but I don't know how to get the process parameter such as operating pressure, temperature, and set pressure?
The set preesure on P&ID show 10 barg seems not possible cause the tube side design pressure is 5 barg.
Please help me out in this complex situation ?
really appreciate it
