BigH, do those pancakes come with maple syrup??? If so, I could eat a good deal more than 3!!
You and VAD have clearly identified many of the problems with developing a half-decent geotechnical design code.
BigH:
The weaker zone should indeed form the basis of design. My point re the geometric average is that given a pile of data about a site (we should all be so lucky), the geotechnical engineer has several possible ways to characterize the site. I'm interested to know: when you have data (CPT, lab, whatever) from a "layer", what sort of average do you use to characterize that layer?
Consider the following problem: if a uniform load is applied to the surface of a perfectly horizontally layered soil then the settlement depends on a harmonic average of the soil layer elastic moduli (see, e.g., Schmertman's formula and write it as settlement = (stress*depth)/E_eff... E_eff is a harmonic average of the layer moduli). Alternatively, if the soil is perfectly layered VERTICALLY, then the settlement of a (rigid) foundation depends on the arithmetic average of the elastic moduli. There are no formula for this case because it hardly ever happens.
Note that the geometric average lies between the arithmetic and harmonic averages.
Since soils are almost never vertically layered, and only sometimes perfectly horizontally layered, the arithmetic average (the one we mostly use) should be almost never used, and the harmonic average sometimes used. This suggests that, in the lack of detailed knowledge about the layering, that the geometric average is a reasonable choice. It is also a "cautious estimate of the mean", as specified by several codes. The use of the geometric average to specify soil properties has also been found to be reasonable in areas such as flow, bearing capacity, and slope stability (in all cases, the "weakest path" principle exists).
In the above argument, I am really just suggesting that if you have no overwhelming reason to use the arithmetic average, you might want to consider the advantages of the geometric average in general practice as a "cautious estimate of the mean".
Regarding your last few questions: I'm in Nova Scotia (well, actually, I'm in Australia right now, but normally I'm in NS), I'm on the Canadian Highway Bridge Design Code (Foundations) Committee. I don't favour this code over CFEM (2005, if it ever appears) at this point - I am merely looking for the best solution. Regarding downloading codes... unfortunately, most codes are now both expensive and protective. You can find the NCHRP and FHWA reports at
under "Related Publications". Contact me directly for more information. I expect you can figure out how.
VAD:
I agree completely that the codification of geotechnical parameters directly is not a good thing. There is absolutely no question in my mind that geotechnical insight should govern designs. As you know, geotechnical engineering involves many uncertainties that can only be properly captured by experience. Have you read Steve Vick's book "Degrees of Belief: Subjective Probability and Engineering"? I highly recommend it.
However, the problem is this: How can a geotechnical design code be formulated if everything is to be left up to the geotechnical engineer? Is that what the structural engineers did?
I would have no objection to NOT working on a geotechnical design code if all geotechnical engineers were equally experienced and if all geotechnical engineers were happy to operate solely on the basis of past accumulated experience. However, we have to face the fact that our (e.g. your) years of experience and your ability to extend that experience to new problems can only be passed to the next generation by an equal number of years of experience under the current educational scheme.
Structural engineers use their code to pass on a great deal of their experience. Can we not make use of the same model?
I am not suggesting that we develop a code which eliminates subjective thought and the benefit of experience. I am suggesting that we need a code which 1) guides the inexperienced, 2) allows input from research to help extend experience to new problems, 3) allows geotechnical engineers to be on the same playing field as structural engineers.
Your input is definitely essential. I think that you and I and all geo-engineers need to come up with a design code which bows to experience but which guides the inexperienced (for the safety of us all!) and allows for the input of new research results so that we can produce competive yet safe designs. The trick is to embody your experience along with that of others from around the world while remaining open-minded, yet logically critical, during the process. It is hard not to be blinded by what we know.
(Imagine two beer glasses clinking)
Appendix: Various Common Averages
- the arithmetic average, the most common, pays no
attention to magnitude
- the geometric average, a little more complicated, is
influenced by low values,
- the harmonic average (see Schmertman) is strongly
dominated by low values.
Arithmetic Ave:
n
x_a = (1/n) sum x_i
i=1
Geometric Ave:
x_g = n'th root of (x_1 * x_2 * ... x_n)
n
= exp{(1/n) sum ln(x_i) }
i=1
Harmonic Ave:
n
x_h = 1/[(1/n) sum 1/x_i]
i=1
