It was a terrible event that our reciprocating compressor cylinder has been heated to make the paint on the cylinder smoke found by CCTV.
We discovered the valve disk plate in the second stage inlet has broken, so the second stage didn’t work and cause the safety valve on the first-stage outgoing damper blew out. After about 10 minutes, we found the second stage inlet has smoke went out since the temperature rose extremely high.
During this process, we did not receive any alarms from the compressor and the temperature located in the damper indicated normally. We decided to add a flow meter in the discharge line to monitor all stages capacity.
Does any one have such experience and how do you prevent the problem of compressor valve failure?
