The phenomena ôslug flowö in two phase pipes 1
2phase
Geotechnical
IS
Dear participants!
I have a problem maintaining the estimated performance in a two phase pipeline transporting steam/liquid from a well to a power plant, due to a decisive slugflow in the pipe.
Illustration:
The pipe is horizontal, well temp. 240°, pipe pressure 6 bar (gauge), pipe diameter 406 mm (16”). The pipe is designed to transfer 10 kg/s of steam and 50 kg/s liquid (brine).
All tips for approaching the phenomena “slug flow” are appreciated
Sincerly, 2-phase
I'd post this question in either the mechanical engineering area, or the petrochemical area. I doubt you will get many responses in this forum -
Good luck.
[pacman]
Please see FAQ731-376 by [blue]VPL[/blue] for tips on how to make the best use of Eng-Tips Fora.
