Hi All,
Can someone shed some light on TF diff stability test shorting the HV and LV winding to bypass TF impedance. How is the injected current controlled as I believe there will be theoretically 0 Z.
The reason to go in this path is because of not having enough current with the standard stability test setup.
Thank you.
Thank you.
