Texture rendering problem
  • Thread starter Thread starter boleslawny
  • Start date Start date
B
boleslawny
Guest
Hi all,
So, my problem is: I've applied a simple texture (external photo*.tif)to some surfaces of my part, but whenever I click render option(small pot), my texture became black after the render is ready. I have a feeling that I'm missing something really easy...
thanks
Boleslawny
have you "checked" the "appearance texture" in rendering setup? (under "options" if you are using photorender)
//Tobias
Edited by: tobbo
Yes, I did
and it doesn't help at all.
When I turn on View-> Model Display-->shade "real time render" or something like this (I do not have proE in front of me), and then I click "appearance texture" on and off, everything works and texture disappears and appears. But then when I click render button it just do not render my textures.
hmm in might be because ofhigh reflection of surface on which is the texture applied.
or try to export your image from tiff to lets say png or JPEG and do the same thing ... if it still wont work then it might be problem in Pro/PHOTORENDER .... this basic rendering module does have problem with some kind oftextures sometimes (Photolux does not have any problem with 40MB big tiff texture ..) ... hope it helps
Itdid not help. IworkwithWF2, but next week there isa change to WF4 so I hope this will solve my problems:).
Thank you for all answers,
Boleslawny
