text turned into pocket or solid then removed?
NCDMAN
Automotive
Mar 22, 2005
1
Hi all,
In Catia can you create different types of text, then explode the text and use the text to create a pocket into a solid or can you create a pad of text? we current use a cad/cam pakage called Cimatron that can do this. Catia should be able to?
Thank you,
Ncman
Hello Ncman,
While I don't know of a way to do this directly in Catia, a company we deal with have written a macro that takes user-defined text and generates sketches for letters and numbers from a catalog of standard letter sketches. These sketches could then be used to generate pads / pockets.
If Beethoven had been killed in a plane crash at the age of 22, it would have changed the history of music...
and of aviation.
