I am trying to find a definitive answer to a question regarding how to properly ground a shield on a medium voltage cable. I've got a 1200 HP 4160V motor, and I have shielded cable running from the breaker to the motor. The guy who did this last grounded both ends of the shield. The stress cones are in bad shape, and I believe it is because of having both ends of the shield grounded. I personally believe the cable should be grounded at one end, at the breaker only. But I cannot find any text which states one way or the other.
IEEE Red Book says that there "is much disagreement" in regards to this subject. I am looking for a source which will explain what benefit you get from the different methods of grounding. If you know of such a source, please advise.
