there are generally two common types of two speed, AC induction motors:
one winding or two winding.
IF you have a two winding, the windings are separate which you can easily determine by taking resistance readings between leads. You do not need markings, simply power one set and separately isolate each lead of the other winding - after you determine which speed is which.
If you get resistance between all leads, then you have a one winding. If you have this one, let me know and I'll give more detailed instructions. When you finish:
Low Speed Connection
Leads 1,2,3 are connected to power and leads 4,5,6 are open and separately insulated.
Hi Speed Connection
Leads 6,4,5 are connected to power and leads 1,2,3 are connected together and insulated.
Both variable torque and constant torque use the same connection.
As StarDelta has pointed out there are many strange connections. Hopefully you will have the two separate windings.
