nycstructural
Hello all. I'm working on a 4 story brownstone renovation project where the architect wants to open up the lowest level of the rear facade (leading out to the rear garden). I have designed steel moment frame to support the wall above and resist lateral forces. The contractor has now hired us to design the means and methods to carry out the work. The facade is 16' wide and consists of 3 wythes of brick. The rough opening will be 13' (finished opening is 11' after the moment frame is installed). I'm suggesting clamping the wall just above the proposed opening using two stiff MC's with through bolts. The channels would be supported by perpendicular beams through the windows (rather than needle through the brick piers). I'm at a loss as to what capacity to assume for the bolts. Should I specify a torque to develop a clamping capacity? Can anyone provide some guidance?
