bbnc1
- Mar 6, 2007
- 9
I tried reading all the threads to see if there is already a topic on this but couldn't find any. I have an application where one end of SS container is attached to Liquid Nitrogen source and the other is open-end to accommodate for air expansion when LN2 is filling the enclosed container. My question is what will the surface temperature of the SS container be if not insulated (i.e. -300F?) and the LN2 is filled. Does the thickness of the container matters? What kind of welding is needed to make sure the cold stress doesn't cause leak? Will there be condensation inside the container? I am not in this field, so I don't where to start the research. Please help. Thanks!
