In a forum I'm a part of there were a couple of people saying it would be okay to drive without a radiator fan in traffic as long as you turn the engine off at each light to keep it from overheating. While I understand their intuitive thoughts on this I've known engines to actually spike in temperature a bit after being turned off. Even though you're not generating any more heat through combustion, you've also lost the forced convective cooling of the coolant system. Since the heat that has already been generated has no where to go it ends up increasing the core temperature of the motor itself. I've witnessed this both in a car that I had many years ago that I drove for awhile without a radiator fan and in an electric motor that I did tested with thermocouples under load.
I've been trying to find more data about (and perhaps a name for) this phenomenon and since I've been having difficulty finding any type of source I wanted to confirm I'm not crazy as well.
Thanks for the help!
