TMEldridge
- Sep 23, 2003
- 27
I have what may be an easy questions...
I am designing a system involving a steam-water heat exchanger. The steam header is superheated steam (250psig, 600degF), and there is a pressure reduction station (2 PRV and desuperheater) between the header and the heat exchanger passing up to 74,000 lb/hr.
Problem is I need to design for failure of any one component, which means a pressure relief and some type of compensation in case of desuperheter failure. The end product will be steam at 60 psig and 375 deg F. The heat exchanger is rated for this, but not the ~550 deg F if no desuperheating takes place.
How do I assure that the still-superheated steam will not be able to enter the system in case of desuperheat failure? T&P valves seem residential/commercial only.
Thought?
Thought?
