bmagdalena
Hi all,
I was tasked with calculating temperature on the other side of fire wall if the fire breaks down. Normally Im doing structual calculations thats why I need some help. I have sample calculations and "heat transfer" by Mills.
I have 2 mobile facilities that are next to each other, about 9" gap. I need to calculate what temperature will be on the other side of the wall, if there is fire on one side. If we have to we can make gap between them to be about 2feet.
based on the sample calculations we assume that fire will have temp of 1200K, first wall has (2) 12gage steel walls with 2" insulation inside. assumption is that fire will emitate radiation heat of 117.6kW/m2 (that is calculated from Stefan-Boltzman law), and then that heat was used to calculate temp on the other side based on conductuion law. what I dont understand insulation resistance was ignored and resistance of steel, which is almost nothing, was used to get temp on the other side.
anyone have any idea?
