Temperature Gauge good for 2500 deg C
richissa
Does anyone know if there are temperature gauges that can read up to 2500 deg C?
This is to be installed on a reactor in a chemical plant
I've not seen anything that high? Can it be infrared optical?
please do not double post.
There are temp transmitters with local readout if this serves the purpose just as well. If you need a larger readout than the usual back of TT local readout, ask your instrument engineer to set this up for you.
