Sep 23, 2022 #1 richissa Mechanical Joined Nov 5, 2013 Messages 30 Location US Hello, Does anyone know if there are temperature gauges that can read up to 2500 deg C? This is to be installed on a reactor in a chemical plant
Sep 23, 2022 #2 dik Structural Joined Apr 13, 2001 Messages 26,111 Location CA I've not seen anything that high? Can it be infrared optical? So strange to see the singularity approaching while the entire planet is rapidly turning into a hellscape. -John Coates -Dik Upvote 0 Downvote
Sep 23, 2022 #3 EdStainless Materials Joined May 20, 2004 Messages 16,352 Location Waukesha WI USA please do not double post. = = = = = = = = = = = = = = = = = = = = P.E. Metallurgy, consulting work welcomed Upvote 0 Downvote
Sep 23, 2022 #4 georgeverghese Chemical Joined Mar 19, 2015 Messages 5,087 Location AU There are temp transmitters with local readout if this serves the purpose just as well. If you need a larger readout than the usual back of TT local readout, ask your instrument engineer to set this up for you. Upvote 0 Downvote
