Alejandroh
Chemical
I would like to ask a (complicated) question.
During eventual special situations (startup/shutdown), it could be possible to have a temperature drop below the minimum design temperature (i.e., -45 degC for killed steel) due to flashing of the process liquid.
However, we will not have continuous operation at this low temperature. After the eventual flashing of the liquid, the system will gradually warm up again. What will happen to the material of construction in that case (killed steel)? Will it fully recover its mechanical integrity or is it still possible to have a brittle fracture?
