Clyde38
- Oct 31, 2003
- 533
When calculating permanent magnet electric motor performance, the variation of the magnet (temperature coefficient of Br) and the winding (temperature coefficient of Resistance) over a temperature range is factored in using the value of thermal resistance (at some ambient temperature) published for the motor assembly. The temperature coefficients published for magnet materials and winding materials is assumed to be linear over a certain temperature range. Does the thermal resistance vary with respect to the change in temperature? If so, how is this characterized?
See reference at this site:
I feel that the thermal resistance should vary since the materials that make up this resistance (air, copper, steel, etc.) change properties with temperature.
[link ]
[/url]
[link ]
