Guys,
I am chasing a theory on a dead head pump test. I have a multi stage centrifugal pump that's manufactured deadhead pressure @60hz is 808 PSI (20 degrees Celcius). I am currently testing this pump in a closed loop which runs through a choke setup which is causing the liquid in the tank to heat up. I tested the pump deadhead pressure at different liquid temperatures and got these results:
Degrees (C)- Deadhead pressure
42 - 801.9
37.5 - 803.6
36.2 - 805.2
The trend is obvious but i just wanted to verify if this is a fluid loss or a mechanical loss? Is there a direct relation between the temperature and the pump output?
I am thinking it is to do with the total NPSH of the system and as i increase the temperature i am reducing the vapour pressure causing a drop in head pressure.
Please any advise would be greatly appreciated.
Dooka
42 - 801.9
37.5 - 803.6
36.2 - 805.2
Dooka
