Fourier's law is the basis for heat conduction:
Q = -kA(dT/dx)
Generally speaking the temperature change from one side to the other of a wall of thickness x and surface A (perpendicular to heat flow), with a thermal conductivity k, depends on these and on the heat flow Q:
T2-T1=(Q/A)(x/k)
x/k is known as thermal resistance.
Please note that T drops in the direction of heat flow.
For cylinders as in thick-walled pipes or vessels with inner radius r1, outer radius r2, and length L, with heat Q flowing outwards,
T1-T2= Q*ln(r2/r1)/(2*pi*L*k)
One always has to keep in mind the consistency of the units used.
