Teamcenter
deerkill
Aerospace
In Teamcenter 2007 is there a way to change the end item type?
Deerkill,
Not that I know of. But then again, your problem might be that you, sir, are a pirate! Arrrrr! Good luck with ye Team Center problem!
assuming that you are working in NX.far as I know, you can only change Item type (of a part file)in NX. File->New->New Item type and change the selection.
I'm sorry, I mis typed. Open the file in NX, then select File->Save As->New Item type and select the item type you need.
