Tapering a revolved surface 1
ninerocket1
I need to model up a curved tunnel gate for an injection mold. I am simply revolving a circle about 180 degrees to create sort of half a donut. The problem I have is how to get it to have a 3 degree taper from one end to the other.
Any help would be great.
Taper command won't work?
Do you know the 'unwrapped' length of the gate? If you do, extrude in a straight line with 3 degrees draft & use the start & end diameters to perform a swept free form feature with an arc as your guide string.
Tim Flater
Senior Designer
Enkei America, Inc.
Thanks Tim....I got unigraphics kind of thrown at me without training. I had to mess with the way I picked the sections but got it modeled up this morning.
Jim Walker
Tim,
I did know approximately how long the pull would be,
So I did as you suggested and drew an arc the radius I wanted , put the center of the 2 diameters at the end points of the arc. Rotated the arcs so I could use the swept
command. Almost left something out, when I first attempted this (using complete circles) the computer would twist the shape (going to a thin section in the center of the body.
I had to split the circle into 2 arcs and pick the 2 arcs for my section, (1st and 2nd)this gave me a very usable body well within the tolerance I had. Just had to be sure that I pick the sections either both outside the string or both on the inside. Hope this explains my procedure so you can understand.
Thanks Again....Jim Walker
Yes, I understand.
You have to have 2 section strings (circles) & 1 guide string (an arc that defines the sweep path). I played around with it a bit today & got it to work out. I ended up having to force the alignment relative to an axis that came through the center of the arc that I used as a guide. You also have to be careful where you select the 2 circles (if you're sweeping a full 180 degress), as that can cause twisting as well. If I remember correctly, the red vector arrows had to point in opposite directions.
Tim Flater
Senior Designer
Enkei America, Inc.
