Taper of 1:50
srirou
IN
Hi friends,
Please help me how to calculate the taper given as 1:50 in a slope is there any method how to calclate the taper.
Thanks in advance!
Srinivas
No, from your drawing there is no way to calculate the minor diameter.
1/50 = (D-d)/L
D = large diameter
d = small diameter
L = length of taper
or
D - d = L/50
Ted
Unless you give it as a function of length.:-P
So, hydtools, what is the length ??
benta, I have no idea. That's up to the srirou to decide.
Obviously it is a missing piece of information. That is what the equation illustrates.
Ted
Inch taper pins are usually 1:48
Metric taper pins are usually 1:50
So d = D - L/48 inch sizes
d = D - L/50 metric sizes
L is length of pin
Maybe I'm missing something. Taper is simply rise over run, so 1:50 means 1 unit vertical to 50 units horizontal. The angle is then arctan(1/50) = 1.14576 degrees. If the taper is INCLUSIVE, then divide by two to get the face angle.
For example, I have a premium thread of 3/4 TPF (taper per foot)imperial. This means 0.75 inch rise for every 12.0 inches of run ON DIAMETER. The required angle is then 0.5 arctan(0.75/12) = 1.78817 degrees. This would be the standard half angle cone for LTC threads for oilfield casing. API listing is 1 degree 47 min.
You don't need diameter, just the understanding if taper is measured inclusive thereof.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
If you have the taper rate(1:50) you do not need to find the included angle, just use the ratio to find the unknown diameter for a known length. 1 unit diameter change for 50 units of length.
Ted
