I have read a few threads about ring walls and have a different question.
First off, I am not an engineer. I work at a small power plant and we have a 26' x 26' water storage tank that sit atop a 4' ring wall. I noticed water leaking around one side of the base of tank. The ringwall was damaged slightly during the 6.5 San Simeon Earthquake back in 2004.
We filled the cracks in the foundation with an epoxy. The epoxy has since cracked. I have noticed that the concrete under this section of the tank is about 10 degrees hotter than the rest of the ring. Is this significant?
I believe the ring is 2' wide and has anchors to conform with Seismic zone 4.
We plan on going into the tank in May to inspect the floor. Is there anything else I should be concerned with? Is it possible that the leaking water is permeating into the concrete causing it to be hotter at that point?
Thanks for any replies.
