Does anybody have experience or have seem an steel open top tank built from large diameter pipe. I would like to build an open top water tank about 8ft diameter and 20ft tall. In terms of trying to build it at a low cost, I was thinking on buying thin wall 96" pipe x 20ft long and have a shop weld a bottom floor to the pipe and stand it up and use it as a tank.
I believe the industry standard is to buy a welded steel tank or a panel bolted tank, however, I am hoping the large pipe turned into a tank is a lower cost alternative. Btw, I am not interested on plastic tanks.
So in terms on trying to build a steel tank at a low cost. Anybody have experience taking this approach?
Thank you
Thank you
