gr8scot
- Feb 7, 2006
- 6
I need to spec a level transducer for a vertical tank filled with vegetable oil. I would like to learn the steps involved for doing this. Kind of an "idiots guide", if you will.
I know the height of the liquid in the tank: 17 feet.
Tank inside diameter: 89.75 inches
Specific gravity: 0.9450
I have looked at transducer manufacturers web sites and they seem to use different methods for defining the ranges available: psi and inches of water. What other info do I need and what are the steps involved in determining the correct range of transducer to use?
Is there an existing site for this type of info?
Thanks in advance.
Thanks in advance.
