PipingEquipment
I know its poor engineering practice to put a nozzle on the outside of a head going through the knuckle radius, but my question is does the ASME Section VIII div 1 Code allow (or prohibit) a nozzle that is truly tangential with the OD of the Head (or Shell), that is to say can a nozzle with the same thickness as the head be pushed so far out that the OD of the vessel is the same as the OD of the nozzle (ie a nozzle that takes up side wall)? This is for a flush on a horizontal tank, and the nozzle is positioned on the extreme lowest point possible so that the vessel can be flushed of all liquid (ID of straight flange = ID of nozzle), and the nozzle is inline with the longitudinal direction of the shell.
I wasn't sure if code barred this because the philosophy of replacing what you take out seems like it may be violated if you are essentially butt-welding a nozzle (on the outermost portion) to the head but no way to RT it to bring the joint efficiency to 100%. I think I've seen this done but would like a more experienced vessel designer to confirm or deny.
Thank you,
-Kyle
Thank you,
-Kyle
