redtrumpet
Is anyone aware of any standards for, or have references for or experience in, constructing system voltage phasing diagrams?
Our client has several systems that were originally designed as radials. They now wish to tie together the secondary side of these systems to allow parallel operation if desired. All systems step down from 63 kV to 13.8 kV through delta-wye transformers.
Unfortunately, there are a hodgepodge of primary connections read H1-H2-H3: A-B-C, C-B-A, C-A-B, and B-C-A. This results in 60/180 degree phase shifts on the secondary X winding between the ccw and cw primary-connected systems, and 120/240 degree phase shifts between ccw primary-connected systems with rolled leads. We are constructing a phasing diagram to indicate the phase relationships between systems in order to document the present arrangements and to plan corrective action.
There are four engineers, including myself, with input to the diagram. However, we all have differing opinions as to how to represent this information on the phasing diagram.
I have reviewed ANSI C57.12.70 and Stevenson's treatment in "Elements of Power System Analysis". However, they seem far from definitive in actual standard practice for representing phasing on the drawing. We wish to maintain the phase sequence between the H and X windings ie. if H winding is C-B-A, then X winding is c-b-a. C57.12.70 and Stevenson seem to support arbitrary relabeling of phases on the X winding. If we maintain sequence between H and X, does this mean we only show a maximum 30 degree shift in our X phasor relative to our reference, rather than the 30, 90, and 150 degree shifts depicted in ANSI and Stevenson? We plan to use the 63 kV system phasor as a reference with A at 12 o'clock and ccw rotation. Any ideas?
