I have a site where there are various existing power monitors connected to the Ethernet network. I need a vendor to pull that data off the LAN, perhaps do some simple number crunching (nothing more complex than add the kW's from a couple meters together), and display it (perhaps on an LCD showing a one-line diagram with switch positions and kW at each switch).
It's not clear to me what vendors would be capable of this. The following come to mind:
+ Electrical Mfgrs (Sq-D, C-H, GE, Siemens, etc)
+ Power Meter Mfgrs (Dranetz, PMI, Fluke/RPM, etc) - and yes, I realize that PMI = Sq-D now...
+ BMS Vendors (Johnson Controls, Andover, etc)
Am I missing any obvious sources to integrate these meters into a central display station?
Also -- it's very unclear to me what issues I might need to be aware of with integrating meters from various sources -- can any system integrator work with any IP-based (or Modbus over Ethernet) meter? Will there be any shocking cost surprises due to mapping meter addresses?
Will all the features of all Ethernet meters be available to any selected system? For example, waveform capture -- while I have no immediate need for that, perhaps some monitoring systems would be able to handle that data at little or no cost, whereas other systems might not be able to access that information.....
Any other pointers on this?
