Syntax error in formula editor
Jaani
20
I wanna use a custom syntax in formula editor. I don't have any problem when my syntax is simple including + - * /, for example (2*4mm). But when I try something like sqrt(16mm), an error message pops up.
What's the right syntax for something like 10 mm + square (100mm) + (2mm)3?
Good morning,
Sqrt and cube must be done on REAL operands.
Try sqrt(100mm/1mm)*1mm
Best regards,
Costin Ruja
Tried it successfully, thank you, Costin.
I'm not familiar with writing syntax in CATIA. I couldn't apply cube syntax. how should I write (100mm)20?
The symbol for raising at an exponent is ** (double asterisk)
Looking at your first post, it should look like this:
((2mm/1mm)**3)*1mm
Best regards,
Costin Ruja
Nothing else, except appreciation. :)
