Symmetry Annotation
BridgeNut
Computer
CA
I'm working on some drawings (making new drawings for reference) for a steel arch bridge built back in 1893, and have some of the original shop drawings.
On some of the drawings only one-half of the part is drawn (up to the Centerline) and noted: "SYM ABT CENTERLINE".
Am I right in assuming this means symmetrical about centerline, if so is this annotation still used today?, if not what else would be used.
Many thanks,
Gord
I think you are safe in your assumption, it was common in the pre CAD days to have shortcuts like this in drafting practices. I was taught not to use section lines in my early career before we had modern CAD systems. The ASME standard fig. 1-33 shows a method for implying symmetry and I have heard it mentioned here before, but, I have never seen it used on a modern drawing.
Hi Bridgenut
Yes your assumption is correct and I have recently seen CAD drawings using the same terms.
desertfox
There is a GD&T symbol for symmetry as I recall though I believe it has wider application in ISO rather than ASME.
What you're talking about is subtly different but I think the idea is still shown in the relevant ASME spec whose number escapes me and I'm not at work to look.
I don't think the note is implying any GD&T constraint, simply that only half the bridge is drawn and the undrawn portion is a mirror image of the drawn portion.
My CAD system will make a half view and place 2 parallel lines at either end of a symmetry line per either ISO or ASME. I don't know which specific parts of the standards cover this.
dgallup,
Y14.5M-1994 shows what you have described in the figure per my above statement.
Frank
Thannks Frank I was thinking Y14.3 but as you say it's in 14.5.
