Jan 31, 2025 #1 kremenco Mechanical Joined Feb 24, 2005 Messages 24 Location AU Hi Frineds, How is angle needle valves shown in P&IDs or any specific type of angle valves for that matter? Thanks Ranjit
Jan 31, 2025 #2 pierreick Chemical Joined Nov 20, 2005 Messages 1,541 Location TH P&ID Symbols - EnggCyclopedia A quick look at P&ID symbols for heat exchangers, pumps, compressors, instrumentation, storage tank & vessels, actuators, valve and fittings. enggcyclopedia.com Pierre Upvote 0 Downvote
Jan 31, 2025 Thread starter #3 kremenco Mechanical Joined Feb 24, 2005 Messages 24 Location AU pierreick said: P&ID Symbols - EnggCyclopedia A quick look at P&ID symbols for heat exchangers, pumps, compressors, instrumentation, storage tank & vessels, actuators, valve and fittings. enggcyclopedia.com Pierre Click to expand... Thanks for the link. However, it does not have symbol for angle needle valves. Kind Regards, Ranjit Upvote 0 Downvote
Jan 31, 2025 #4 pierreick Chemical Joined Nov 20, 2005 Messages 1,541 Location TH should be the combination of both, needle and angle valve with the stem @ 45 angle. With a reference on the PId , it will be clear for everyone. Pierre Upvote 0 Downvote
Jan 31, 2025 #5 LittleInch Petroleum Joined Mar 27, 2013 Messages 22,998 Location GB For something as specific as this, just make it up and put it on the legend sheet. There are still many variations of the same things like ball valve etc. Try ISA if you you want to go back to basics Upvote 0 Downvote
