rockman7892
I am currently evaluating low impedance vs high impedance bus differential schemes for a 13.8kV Switchgear replacement project. Existing switchgear does not have any bus differential but new switchgear will be provided with bus differential. Switchgear is 3000A M-T-T-M with a total of about 14 breakers including all mains, ties, and feeders.
I know that both schemes provide pretty much the same response times so choosing high vs low becomes somewhat of an application consideration. From what I have seen elsewhere two primary considerations become available space (dedicated CT's for high impedance scheme) and cost (low impedance system with higher cost).
If new switchgear has space to accommodate dedicated CT's for high impedance schemes and the economics point towards the cheaper high impedance scheme, what other factors should be considered when evaluating these schemes?
Is the slope differential low impedance scheme typically more secure than the voltage restraint used in the high impedance scheme? Should preliminary saturation calcs be evaluated in the criteria for selection?
