itsmoked
- Feb 18, 2005
- 19,114
Hey would somebody give me a quick confermation of what a pushbutton switch is that is called:
SNAP ACTING MOMENTARY PUSHBUTTON
( ) denotes momentary
SPDT ON-(ON)
I have been staring a switch descriptions for two days and have now got myself confused.
Of course it is a Single Pole Double Throw switch.
Which means it has a common and two "switched" terminals.
What I need is a switch that is closed when the plunger/actuator is out. And open when the plunger is in. I need this switch to detect when a lid is opened by closing. The same exact function as a car door switch... Light on with door open.
I am looking specifically at:
Part number: 8121SHZGE
And before you say it..
I can't use a $1 car door switch because this switch is in "Dry contact service" (need gold).
I am confused buy the "ON-(ON)" nomenclature.
Does this mean...
When the switch is just sitting there the plunger is out all the time?
And from the common to one terminal you will have a closed switch?
And conversely when the plunger is depressed the aforementioned closed switch is open and now from the common to the other terminal will be closed?
Hence the function I need is to use the "first" contact set described immediately above?
Thanks for the help!
SPDT ON-(ON)
![[lol] [lol] [lol]](/data/assets/smilies/lol.gif)
Does this mean...
