Sustained torsional oscillation 1
tokitalk
Anyone has ideas on effective countermeasures?
an engine crankshaft undergoes sustained torsional vibration (oscillations), and there are many different damper designs available to address that. Look up "torsional vibration damper", "TV damper" or (ughhh) "harmonic damper."
(or even worse, "harmonic dampener")
Another strategy may be to separate torsional resonant frequency from excitaitng frequency and it's harmonics.
(2B)+(2B)' ?
Eliminate the periodic force/displacement function...
tokitalk,
Stop twisting it back and forth.
JHG
Would a longer shaft intended to reduce shaft stiffness be a viable option?
Changing the stiffness or mass of system will change its natural harmonic frequency ( stiffer is higher, heavier is lower) and prevent system resonating if exiting frequency and natural are similar. However that only reduces resonating. System may still vibrate, Just at a different frequency.
It is easier to damp higher frequencies so increasing stiffness and adding damper will help.
I agree with Electricpete, the first usual suspect you should look at is resonance. Check that the excitation causing this has a frequency component close to the natural frequency of the vibration mode that's responding. I'm assuming of course that you have no control over this excitation, but still you must know what it is.
You should know if it's more practical adding or removing mass or stiffness, specially since you have provided preciously little information on your problem.
The dumbest solution is adding mass. If this is a rotating shaft, make sure it remains equilibrated, that is: add something symmetric across the shaft, or equal weights on diametrically opposite sides; and either add that at the exact axial position of the center of mass of the rotor, or if you can't place it there, equilibrate two sets at either sides of the center.
You can try active damping with a motor and controller but it would be best to remove the cause of the oscillations.
Peter Nachtwey
Delta Computer Systems
Forgot to add in the above post Swayaway has some online calculators that maybe of some help.
That would generally decrease the resonant frequency. It certainly might be a good solution if you are experiencing resonantly-amplified vibration from a constant-frequency excitation (like an electric motor-driven load, no vfd). On the other hand if you have a varying-frequency source of excitation (like in a car), it may not be practical to separate resonance from all possible exciting frequencies in which case the other solutions like damping would be more effective.
(2B)+(2B)' ?
Usually the best bet is to change the stiffness of your part or the location of the supports to move the resonance out of the operating range. Increasing or decreasing the length would certainly change the frequency. A longer shaft would have a lower natural frequency, while a shorter shaft would have a higher natural frequency. You also may consider changing the diameter or wall thickness (?) of the shaft.
If it's impossible to get the natural frequency out of the operating range, dampers may be used. However damping is difficult to quantify, so it's preferred to avoid resonance.
tokitalk (Mechanical) 27 Jan 11 19:12
AKA "quill shaft". Commonly used to avoid TVs by lowering the resonant frequency.
Engineering is the art of creating things you need, from things you can get.
Thanks for all the inputs....our current system utilized a relatively longer shaft, weight is a premium, so anything in the realm of adding mass/increasing diameter are not viable options. I must also add that the shaft is designed to see torsional loading only....no bending loads are intended, that is not to say parasitic bending from say misalignment may not arise.
