Everynameistaken
Hello All,
I am looking for some info on what the surge capacity is for a ASME B16.47 flange.
We are designing a high pressure piping system for a hydro plant, typically when the pressure is this high (6000 kPa) we only use CJP welded steel pipe. I have a situation where the client is asking about the use of flanges for the last connections.
We defined three performance levels for the system:
Normal operation
Emergency operation and
collapse prevention.
For these performance levels we have simple stress criteria of the pipe and run a full transient analysis for the system and can compare the von mesus stress to the limits.
My question comes when dealing with the flange! I understand we can compare the working limit of the flange for a given pressure class, material class and temperature against the normal operating condition. I know the test pressure for the flange is 1.5 times the working pressure.
What is the limit for the flange pressure when dealing with different performance surges? typically for emergency we use 0.75 fy for the steel pipe limit and collapse prevention increase further to 0.7 or 0.8 Fu, not sure how to work with surge and a flange, any help would be appreciated!
Normal operation
