4loren
- May 19, 2005
- 2
In nastran what is the best way to apply a torque along Z axis over a set of shell elements lying in the X-Y. In a simplified example the torsion test will consist of a hollow box. The top of the box (lying in X-Y plane) is essentially glued to a rotating pad. The bottom of the box is constrained in translation.
I assume the best way to apply the torque over the surface is to use a RBE2 and applying a Z moment at the independent node. Is this correct, or do you have competing suggestions? Thanks in advance.
