It seems this pump is causing voltage surges and sags when it turns on and off. It's a 100 Watt pump in a small water circulation unit. There is a bank of LED lights on the same feeder bus (28VDC) which flicker when the pump cycles on and off. After the flickering, the light intensity is normal. We have eliminated possible bad grounds or voltage drops on the power supply.
I didn't design the pump or install it, so I have to take it "as-is", while troubleshooting from the other side of the world. This schematic (attached) from inside the pump shows a FET built-in with the motor. The power is supplied at pin 2, the ground is on pin 9, and the installer connected pin 6 to ground so that the voltage divider R1/R2 would put half the supply voltage on the MOSFET gate. This is a P-channel MOSFET, so I thought the way to turn it ON is to ground the gate with NO resistance. Maybe since there is a positive Vsg this is okay?
I'm also worried about the lack of built-in coil suppression. Not even a diode across the motor terminals. There is no way to open the motor to access the hidden connections. I believe this is the cause of the voltage spikes. How they get out into the rest of the circuits though...
Wouldn't the FET block the spikes when it turns off? Is a spike from the motor fast enough to escape before the FET stops conducting? Is this circuit holding the FET open longer than normal?
Currently the gate is switched floating when "off", but through R2 it gets +28V like a pull-up resistor. Is this good for the P-channel FET?
There is also a possible switch "bounce" in the pressure switch that turns the pump motor on and off. Should I investigate this? (very difficult since the customer has to test for me.)
STF
STF
