pepeuy
- Jul 20, 2008
- 14
Hi everyone.
I'm having some discussions with some colleagues about forces transmitted to static structures linked to pipe supports.
We have a horizontal run of a 30" pipe, with a saddle support welded to it. The base plate of the saddle will be the one in contact with the static structure (the base plate will be the one wearing off, instead of the pipe wall).
The actual question is:
Using autopipe to study flexibility and restraining reactions (using a friction coef. of 0,3 for steel on steel) the axial forces are one third of the vertical loads, that's obvious.
The argument arises when designing the static structures, since I want to consider the axial forces as given by autopipe, and my colleagues (based on their experience) say this forces will actually be smaller, so the structure proposed is weaker at the end.
What should i do?
Thanks in advanced.
What should i do?
Thanks in advanced.
