I'm not aware of a manufacturer. It's interesting how the top and bottom chords are completely different profiles Do you know what the prior use of this framing was? What type of loading will go up there? Light storage?
I know this isnt your questuon, and Its hard to see from the photo, but I'd look into the connection from the steel to the wood ledger on the wall.I've never done anything like this, but I find with wood framed decks, the ledger connections can be tough. Depending on your LL, it might be worth checking those connections. The longer spans between the truss carriers could give high reactions.
-MMARLOW EIT
