SUPERSCRIPTS IN ATTRIBUTED BLOCKS
chicopee
6,199
WHILE WORKING ON A FAULT TREE ANALYSIS, PROBABILITIES OF OCCURENCES HAVING VERY SMALL VALUES OF THE ORDER OF 10^-6 TO 10^-10 ARE TO BE ENTERED IN ATTRIBUTED BLOCKS. HOW CAN THE EXPONENTS SUCH AS -6 BE ENTERED AS SUPERSCRIPTS WHILE TAGGING ATTRIBUTED BLOCKS.
ANYBODY OUT THERE WITH A SUGGESTION?
you could check the font you are using and see if it already contains the characters you need such as ±,¹²³ ~ if the characters do not already exist you could create them using the Private Character Editor, save them with your current font, then insert them using the appropriate unicode
To open Private Character Editor, click Start, and then click Run. In the Open box, type eudcedit
~ for your CAD solutions
