gearcutter
Industrial
This was an interesting investigation.
As a manufacturer; I had a pretty good idea as to what had caused this as soon as I saw the damage. Proving what it was I suspected was occurring was therefore very quick and easy resulting in a happy customer/end user.
The part is a sun gear from a 3 pin planetary set.
Carburize case hardened and gear ground with a crowned profile on a wet gear grinder.
Surface damage is of a consistent nature on all teeth with 2 or 3 of the 18 teeth only showing damage on one end as can be seen on tooth #8 in the image.
Damage is on the loaded flanks only.
These parts normally show very little signs of wear or damage during service life.
Acid etching revealed that a too aggressive grinding operation resulted in the formation of untempered martensite on the ends of the teeth where the grinding wheel approached full depth of the crowned profile.
After further testing; a batch of over 200 parts was subsequently rejected.
The gear grinding machine that had been used to grind these parts is a modern state of the art machine that is designed to lessen the risk of grinding burn by detecting & monitoring changes in grinding wheel spindle speeds & loads.
The manufacturer was relying on this feature in their new machines and consequently had stopped using the acid etching test.
Ron Volmershausen
Brunkerville Engineering
Newcastle Australia
Ron Volmershausen
Newcastle Australia
