I am trying replace some exsiting sump pumps( 4.5 ft in diameter). Sump collect drainage water. For a submersible sump sump (5hp), what should be the maximum starts per hour. I always thought that that this was 6 but I was told that for a smaller pump like this starts can be increased upto 15 starts per hour.
If I increase the starts what precautions should I take to cool down the motor. Should I keep the motor submerged all the time
Also for a small sump pump duplex system that uses floats what should be the recommended depths for the following
1. Depth between the lead pump on and lag pump on? 6"
2. Depth between lag pump on and the high water alarm 6"
3. Depth between the High water alarm and the lowest invert 6"
Thanks in advance
Thanks in advance
