Dear Mr. Grover,
Your basic problem semms to be measurement of the speed of a submersible motor, ie. when in submerged condition. I hope my assumption is correct.
There is a one method for measurement of the speed of submersible motors with much better reliability. However, this method can be used provided the performance test is being done in an open type of well or sump.
The main sensing device is called as Slip Coil, which is mounted over the stator portion of the motor.( at the centre of the stator ). As you may be aware, when the any induction motor starts, there is a back emf generated in the rotor. Due to the magnetic leakage, an emf is generated in the slip coil, with different frequency and is equal to the difference in the line ( supply frequency ) and the one generated by the rotor. To measure the slip, this signal is fed to a centre zero galvanometer, of which neddle oscillates exactly as per the differential frequency. this oscillations are counted and the speed is calculated.
In another method, a special disply instrument is connected to the out put of the slip coil and it displays directly the speed of motor.
The no. of turns and the I.D. of the coil is to be decided based on the stator length, operating voltage and this coil can be used for other motors having the O.D. smaller.
If you can provide me a little information about your motors, ie. the rating, operating voltage / frequency, motor OD etc. I can give you the details of this.
Before I end, let me tell you something about myself.
I am basically an electrical engineer working with KSB Pumps Ltd, India in Marketing department. I have 20 years of experience in the field of submersible bore hole pumps and submersible sewage pumps. My experience includes Research & Development for two years, design 7 years, projects 5 years and now looking after Projects in marketing department. In addition, I am excellent in the field of testing of motors, designing of instrument panels ( for performance testing )and control panels.
I hope this will be useful for you.
Rajendra Joshi
So if you have any problem like the one here, you ask and I will try to find a solution on it.
