Sub sea system
anilkk
IN
We are installing subsea production system in the water depth of about 2700 meters. Would like to know the vendors for supplying proven pipeline connectors (Hydraulic with mechanical back-up) of 2500# class in the of sizes 24", 14" and 16".
Anil
This sort of gear is used by the likes of Haliburton, Stolt Comex etc you could try TD williams in the states???
The companies who provide quick set connections for these diameter casings: Vetco Gray and OilStates, might also be able to help.
Have a look at FMC Kongsberg.
They operate a diverless flexible flowline connection system called ROVCON. This is only applicable if you are laying flexible pipelines.
