rapt
- Oct 4, 2001
- 2,768
Nathan,
Replying to your queries below
- No mention on hot to resolve tangential shear stresses on the node. We need to refer to Stephen Foster presentation to have clarification on this
AS3600 is not a text book. It defines limits on the design methodology. Read a good text book on the topic, or Stephen Fosters presentation if you want.
- In the ACI the development of the tension tie start when the tie meet the concrete strut which make sense because in that region the concrete is in compression as such the tie is confined. Developing the tie before the node allow to have less congestion where the node is.
You cannot logically start the development before the node. The whole logic is that the full tension force reaches the node! There is a further argument that the development should start behind the node, past the end of the compression zone. ACI obviously does not agree, but that does not make them correct!
- Code does not cover confinement of the node if the node is overstressed. What do we do to confine the node? Follow the recommendations for columns?
This is covered in the new Commentary that hopefully will be released soon!
- Bursting of struts for pilecaps? Do we need bursting reo or not? I went to a conference and the lecture mentioned that bursting reo is not required for pile caps, however the core doesn't talk about this.
The Strut Tie chapter in AS3600 (chapter 7) is a general set of rules for the design of strut-tie and ties and their connections.
Pile Caps are a specific application which should be covered in Chapter 12, Design of Non-Flexural Members, but is not covered specifically. So I assume you will have to use some engineering judgement in deciding how to design it, or again refer to text books. But I do not think you can apply a single rule for all struts in all pile caps in this case. I would think it would depend on the arrangement and the location of the compression strut within the pile cap. A strut at the edge could easily burst, while an internal one that is fully confined by other concrete maybe is less likely to burst.
What i meant is that there are a lot of area that are not covered in AS3600. It would be good to have some clarifications.
Again, AS3600 is not a text book. It defines limits on the design methodology. You need to apply engineering judgement in applying the rules as you do for all areas of analysis and design.
Trenno,
Maybe the researcher mentioned is not up to date on S&T and needs to read up on it a little more before making comments like that!
Trenno,
