EngDM
- Aug 10, 2021
- 760
I'm playing around with a simple 7'x12' slab in SAFE, with pin supports at the corners and I am finding that SAFE still wants me to provide top steel. If this slab is truly pinned, for instance formed onto some sort of angle or support with minimal moment restraint and moreso just shear studs to keep it from sliding, how come I am getting negative bending? The supports are currently placed directly at the corner, so it's not like the moment is being generated over top of the support.
I'm not sure if maybe since the pin support is placed at the datum, which coincides with top of slab it is taking the slab as being supported by the top? I tried shifting my supports down by my slab thickness but it throws ill conditioned warnings.
