On my property in the NC mountains, I have an existing wooden 15'x 40' bridge which has allowed cars, timber trucks, to cross a creek. It has seen better days, and I would like to use it as a form to pour a reinforced concrete slab on top of it; ideally being able to be standalone later on. I would dig out a substantial footer on both ends, frame around all sides, lay a sheet of polyethylene, add a rebar grid on chairs, pour slab. I need help with the rebar part, and slab thickness. 1" rebar 12"OC in a 6" concrete slab? Overlay two 20' rebar by adding a third centered at their joint? Would a 2'x2'x15' footer on both ends be sufficient? The slab would actually be 6" thick at its minimum and 10" at its maximum, due to spacing of 4x10s running the length, on top of regular surface. Pic of bridge attached.
